2001 BMW 740 Rear main seal problem
2001 BMW 740
94,247 MILES • V8 • 2WD • AUTOMATIC
HEIFETZ17
  • 10 POSTS
I had a leaking rear main seal. I replaced it, as well as the oil cover gasket right above the rear main. I still had an oil leak, and after doing a dye test, I confirmed oil was still coming out from around the bell housing area.
Are grooved crankshafts a common issue on these cars when the rear main wears out? Are there any other areas I can check?
Thanks very much!
Dec 22, 2009 at 9:23 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
A common problem with any seal that has been leaking is that often the cause of the seal leak in the first place is that it has gone hard and and the soft presser seal is lost, when this happens and it is left for some time, the hard seal lip can wear a small groove in the seal surface, and when the new seal is fitted the lip sits in this same groove and there is far less sealing pressure or the seal can get damaged, there is a quick repair for this, it is called a speedy sleeve , this is a stainless sleeve that knocks over the seal surface restoring a good seal and as it is very thin, seal pressure is not compromised, other possible leaks may be from the rear of the sump.
Mark (mhpautos)
Dec 23, 2009 at 12:29 AM
HEIFETZ17
  • 10 POSTS
Thanks very much for your help. Does the crankshaft need to be removed to fit this sleeve on, or can it be done simply by removing the transmission?
Thanks again, very much!
Dec 23, 2009 at 7:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, just remove the transmission and the old seal, but you best ensure that you can get one this size, not sure about the sizes you can get there, as i am in Australia things can vary here to there, an engine re conditioner should be able to give you the diameter of the crank shaft seal surface.
Mark (mhpautos)
Dec 23, 2009 at 7:41 PM
HEIFETZ17
  • 10 POSTS
Thanks very much for your help!
Dec 24, 2009 at 1:05 AM
