1999 BMW 740 p1420 secondary air circute electrical
1999 BMW 740
140,000 MILES • V8 • 2WD • AUTOMATIC
SCAR09FACE
MEMBER
FOLLOW
does any body know what i need to do to fix this code? please help!!!!!!!!!!!!!
Dec 28, 2008 at 3:08 PM
2CARPRO JACK
CERTIFIED EXPERT
Please be patient, I have sent your link to our resident BMW doctor..........
Dec 30, 2008 at 9:14 AM
DOCHAGERTY
CERTIFIED EXPERT
If the fault was set for secondary air then there is a possibility that there is some restriction/occlusion built up inside the air injection ports and the carbon build-up will need to be removed, or the secondary air pump/secondary air injection valve is not working correctly. How were the fault codes extracted, what device was used?
Dec 30, 2008 at 12:53 PM
SCAR09FACE
MEMBER
i've used two difrent devises one from o'raileys and the other one from my friends shop and they both came up with the same code p1420 i would realy apretiate if u could give me a call if u can i can tell u a little bit better on whats been going on with the car my number is 979-627-3494
