WILL REPLACING THE SPARK PLUGS HELP STOP PLUG WELLS FROM FILLING WITH OIL?
Feb 8, 2009 at 6:02 PM
CERTIFIED EXPERT
You need to check if the valve cover gasket is leaking.
Feb 8, 2009 at 6:51 PM
DOCHAGERTY
CERTIFIED EXPERT
Ras is on the right track. You have valve cover gaskets leaking into the spark plug wells and they will require replacement and there might also be a need for other work such as a valley pan replacement, the PCV plate and the throttle plate profile gasket.
