1999 BMW 740 Hesitation at idle and at very low speed.
1999 BMW 740
102,000 MILES • V8 • 2WD • AUTOMATIC
BOBQ
Multiple cylinder misfire with fuel cut off CODES. Along with speed sensor malfunction CODE. And System to lean codes. Where should I start? Speed sensor?
May 16, 2010 at 8:57 PM
DOCHAGERTY
  • 9,603 POSTS
Do you know Susie Q? Just kidding. The misfire and system too lean faults may be due to a vacuum leak, it may need a PCV plate or maybe it got ran out of fuel. The sensor faults should be specific, which speed sensor? I think this needs to be further diagnosed.
May 16, 2010 at 10:11 PM
BOBQ
The code was P0500 (vehicle speed sensor).
May 16, 2010 at 10:28 PM
DOCHAGERTY
  • 9,603 POSTS
Generic fault codes are not helpful, proprietary scanning equipment is needed.
May 16, 2010 at 10:35 PM
