1998 BMW 740 water pump?
1998 BMW 740
165,000 MILES • V8 • 2WD • AUTOMATIC
98BMWOWNER
I don't have a manual for a 1998 740IL, and it appears as though my water pump is leaking. Water is running from what appears to be the lower mount to the motor and now across the front. Is their any other possibilities, is this a common leak. Could there be another culprit? I flushed the coolant, the leak stopped. I flushed it again, added coolant, and now it's worse?
Apr 9, 2009 at 12:18 PM
DOCHAGERTY
  • 9,603 POSTS
It is possible the water pump is leaking, a pressure test of the cooling sydtem should help pinpoint the source of your coolant leak. Also check the valley pan for leakage, it is an area of possible leakage too.
Apr 10, 2009 at 12:16 PM
