I have a v8 with a zf5hp30 trans. This is a two owner car me being the second It has 183000 miles. I have had is since 90000miles. It has been mantained at bmw shop. Just recently I was getting a clunk on downshift. I took it in to be serviced and check the clunk. They checked codes and it showed voltage fault and brake level sensor. They said they stress tested the tranny and said it needed to be replaced. So I had my wife pick it up. She barely got home on limp mode. I was out of town at the time. I got home and pulled the batt to find it was bad. I changed the batt and now I am getting 2 different codes. P0720 & P0733 It will not hold a forward gear it goes to slipping or neutral. If I putt it in reverse it will go good. I put it in drive and it hits good then goes back to neutral. I am not sure if the trans is bad now or just the output speed sensor. Any Ideas?
Oct 4, 2007 at 11:36 PM
