1993 BMW 740 VIOLENT SHAKING OF ENGINE/ CAR FROM START
1993 BMW 740
100,000 MILES • V8 • 2WD • AUTOMATIC
QUEENCANDII
the car is violently shaking from the turn of the key in the ignition, there are no check engine lights on. I have no clue when the last tune up was done. had full fluid levels. new air filter and belts. 02 sensor. does stall at stops sometimes (has a bad transmission now, could that be causing this problem as well?) did not pass emsstion inspection. in Maryland
Thanx
Feb 21, 2010 at 10:39 AM
DOCHAGERTY
  • 9,603 POSTS
I recommend you seek out a local professional that can perform testing to diagnose the problem. It could be internal engine issues.
Feb 22, 2010 at 1:20 AM
