1992 BMW 735 ENGINE OVERHEATING AFTER REPLACING RADIATOR AN
1992 BMW 735
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
216EDDIE
THE ENGINE OVERHEATED WHILE DRIVING.INSPECTION REVEALED A LEAKY RADIATOR . IT AND THE THERMOSTAT WERE REPLACED. AFTER ADDING COOLANT THE ENGINE IS STILL OVERHEATING, IT APPEARS THERE IS AIR IN THE LINE. I OPENED THE BLEEDER SCREW TO ALLOW IT TO ESCAPE AND START A STEADY TRICKLE OF COOLANT. BUT I AM STILL GETTING AIR AND IT IS STILL OVERHEATING. HOW DO I GET THE AIR OUT OF THE SYSTEM ?THE COOLANT DOES NOT APPEAR TO BE CIRCULATING
Apr 7, 2010 at 12:21 PM
DOCHAGERTY
  • 9,603 POSTS
There is a bypass hose from the radiator up to the expansion tank, if it is clogged, you will not get all the air out.
Apr 7, 2010 at 1:18 PM
