1988 BMW 735 hydro boost problem
1988 BMW 735
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOUT5369
  • 217 POSTS
First let me say this,I don't own a BMW 735i,But what I have is a 1971 Rolls royce that I installed a 1988 BMW hydroboost brake system on,The problem I'm having is the pressure is getting so high in the feed line that I'm burning up pumps,I have manual brakes,but not power brakes,the Power steering works until you apply the brakes then you lose power assist,I need a diagram of the original system for a BMW 735i,Everything I'm using came from a salvage yard,but I removed it and made a note of the hookup before I took it off the car.I did this because the original Rolls Royce system was destroyed,and the cost to repair was rediculous
Aug 6, 2009 at 9:49 AM
LOUT5369
  • 217 POSTS
Nevermind guys,I figured it out,The BMW pump doesn't make enough pressure to make the conversion work,I used a GM pump,now we're good.
Aug 22, 2009 at 7:00 AM
