Steering Lock/Ignition Switch, Removing and Installing :
*Disconnect minus lead at battery.
*Remove and install trim lower section. See: Body and Frame\Interior Moulding / Trim\Trim Panel\Service and Repair
*Unscrew stud screw and pull out ignition switch.
Installation Note !
*Turn back ignition key all the way.
*Position ignition switch at 0.
*Note mark and install ignition switch in this position.
*Loosen wire straps.
*Disconnect single plug.
*Pull off central plug and remove ignition switch.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Aug 16, 2010 at 9:53 PM
