IGNITION SWITCH Removal & Installation Disconnect negative battery cable. Remove lower left dashboard trim. Remove screws and steering column lower trim. Press in retaining hooks on both sides of switch, and pull out ignition switch. To install, reverse removal procedure. Check ignition switch-to-steering wheel lock position.
Sep 26, 2010 at 1:12 PM
