1997 BMW 540i Underneath noises
1997 BMW 540I
165,000 MILES • V8 • 2WD • AUTOMATIC
ALABAMA JOHN
When running at steady speed car sounds like its changing gears up and down constantly but looking at the RPM's staying steady its not changing gears. Transmission works fine and changes as it should.
Also rough roaring noise when cruising speed is steady and car not pulling but maintaining speed. Stops when gas is increased. Doesn't do it ever above 80 MPH.
May be two separate things.
Jul 17, 2010 at 9:55 AM
DOCHAGERTY
  • 9,603 POSTS
Sounds like the transmission is pendulum shifting, it could be software.
Jul 18, 2010 at 1:38 AM
ALABAMA JOHN
Dr. Hagerty,
Thank you for your answer.
If it is pendulum shifting, can the software be reset or what to do about the software?
Could it be the fan sensor or even the catalytic converters since I have 100,000 miles on them?
They are something aftermarket so my check engine light stays on.
Jul 18, 2010 at 12:15 PM
