I want to use my obd sensor tool to find out why the check engine light went on....I can't locate the terminal plug in site. Any ideas?
Mar 15, 2009 at 6:43 PM
DOCHAGERTY
CERTIFIED EXPERT
Because there is no OBDII connection on your 1994 vehicle. You will have to use the 20 pin connector under hood to extract the diagnostic trouble codes and you will need compatible diagnostic equipment. There are several makers of equipment, Baum, Peake research, Autologic come to mind.
Mar 15, 2009 at 9:59 PM
HAILEY2NASON
MEMBER
1 POST
[quote:2138b8dfbe="willeo"]Computer problem
1994 BMW 540i V8 Two Wheel Drive Automatic 81,000 miles
I want to use my obd sensor tool to find out why the check engine light went on....I can't locate the terminal plug in site. Any ideas?[/quote:2138b8dfbe]
Jul 3, 2009 at 10:28 AM
DOCHAGERTY
CERTIFIED EXPERT
Because there is no OBDII connection on your 1994 vehicle. You will have to use the 20 pin connector under hood to extract the diagnostic trouble codes and you will need compatible diagnostic equipment. There are several makers of equipment, Baum, Peake research, Autologic come to mind. Check the O2 sensor, it will command the check engine light on.
