1991 BMW 535i
1991 BMW 535I
121,000 MILES • 6 CYL • 2WD • MANUAL
KAPARICIO
pulls to the right and wobbles around 35 to 45 mph as if the rack and pinion is bad?
Oct 8, 2009 at 8:05 AM
DOCHAGERTY
  • 9,603 POSTS
The E-34 535 has a steering box, not a steering rack. The best suggestion I can make here is to inspect the front suspension and the wheels/tires. If the thrust arm bushings are worn/broken, this could be a reason for the wobbling and for the pull. Also inspect for worn shocks struts and for loose/worn ball joints and tie rod ends, also look at the idler arm, it often has wear at that age and mileage.
Oct 8, 2009 at 8:43 AM
KAPARICIO
Thanks for your help Ken
Oct 8, 2009 at 9:20 PM
