1999 BMW 535
1999 BMW 535
RICKY MOORE
Engine Mechanical problem
1999 BMW 535 97312 miles
how do i put the fan belt back on
Mar 31, 2008 at 1:38 PM
DOCHAGERTY
  • 9,603 POSTS
Pop the cap off the tensioner pulley and turn the torx bolt to the right to achieve adjustment. The belt routing is as follows, over the water pump, under the deflection pulley(the pulley that does not move for belt tension) over the alternator, down and around the power steering pump, then around the crankshaft pulley, then around the tensioner pulley and back to the water pump
Mar 31, 2008 at 6:13 PM
