what posible solution can be with that obd code i am geting p1175 bank2,where shoud i look to fix that problem? thanks
Jan 29, 2009 at 2:30 AM
CERTIFIED EXPERT
P01175
Un-metered air leaks may occur in the following areas causing the above situation:
Intake manifold gaskets may be leaking.
Plug cap(s) and the vacuum hose for the fuel pressure regulator on the rear intake manifold cover (crankcase ventilation valve) may be torn or missing.
I would let a BMW Dealer look at it and confirm that this is the problem with your vehicle.
Jan 29, 2009 at 2:42 AM
DOCHAGERTY
CERTIFIED EXPERT
Look at the inlet air boot at the corner where it turns into the idle air control motor, they get old and tear right there. Go to Realoem.com and look up part #13-54-1-437-191 It gives a nice exploded view.
