2004 BMW 530 hi can you help with code p1175
2004 BMW 530
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
SREKAS1
what posible solution can be with that obd code i am geting p1175 bank2,where shoud i look to fix that problem? thanks
Jan 29, 2009 at 2:30 AM
P01175
Un-metered air leaks may occur in the following areas causing the above situation:
Intake manifold gaskets may be leaking.
Plug cap(s) and the vacuum hose for the fuel pressure regulator on the rear intake manifold cover (crankcase ventilation valve) may be torn or missing.
I would let a BMW Dealer look at it and confirm that this is the problem with your vehicle.
Jan 29, 2009 at 2:42 AM
DOCHAGERTY
  • 9,603 POSTS
Look at the inlet air boot at the corner where it turns into the idle air control motor, they get old and tear right there. Go to Realoem.com and look up part #13-54-1-437-191 It gives a nice exploded view.
Jan 29, 2009 at 6:36 AM
SREKAS1
thans for qiuck response
Jan 31, 2009 at 4:27 AM
SREKAS1
could that couse the problem if i have an oil leak betwen engine block and the oil filter housing http://www.realoem.com/bmw/showparts.do?model=NA73&mospid=47758&btnr=11_2201&hg=11&fg=30
Jan 31, 2009 at 4:51 AM
Your problem has nothing to do with a leak between the two-you need to do what was suggested
Jan 31, 2009 at 4:59 AM
