2002 BMW 530 spraying coolant
2002 BMW 530
FREEBIRDNATION
Engine Cooling problem
2002 BMW 530 6 cyl Two Wheel Drive Automatic 75k miles
the plastic radiator top cracked and leaked. I replaced radiator (myself). Now it is spewing coolant from an apparent safty valve where the upper hose connects to the engine. The temp guage is normal. Someone suggested the thermostat. Could this problem have craked the radiator? Can I replace the thermostat? The system is a little more complex than I'm used to. Thanks.DL.
Sep 9, 2008 at 10:12 PM
DOCHAGERTY
  • 9,603 POSTS
Probably going to need a replacement thermostat installed.
Sep 9, 2008 at 11:42 PM
