2000 BMW 528 Brake pad wear sensor light on instrument pane
2000 BMW 528
50,000 MILES • 6 CYL • 4WD • AUTOMATIC
COOLGPS
MEMBER
1 POST
FOLLOW
How do you turn off the sensor light after the pads are replaced?
Mar 1, 2008 at 6:41 PM
DOCHAGERTY
CERTIFIED EXPERT
The lamp is extinguished by turning the key to the KL-15 position(key on engine off) for about 45 seconds, if the sensors were replaced and everything else is nominal, this should take care of the tattletale lamp for the brake pad monitoring.
