1999 BMW 528I
1999 BMW 528
TRUELOVE
Car overheated. I am going to investigate but is there anything else to replace besides t-stat, w-pump, radiator cap i.e. sensors etc.? Also, looking down at the radiator to the left at the bottom is an electrical plug. On the right side of the radiator about 1/4 of the way down there is an electrical plug in. I am missing whatever plugs into this. What is this plug?
May 5, 2007 at 12:57 PM
MERLIN2021
  • 17,250 POSTS
Does the water temp gauge work correctly?
May 7, 2007 at 5:05 PM
TRUELOVE
The temp gauge never went past half way. The blowback was coming through the bleeder valve on the expansion tank. When the car cooled the I checked the bleeder valve with my fingers the top of it snapped off and I barely touched it.
May 7, 2007 at 8:00 PM
MERLIN2021
  • 17,250 POSTS
this tank is made of? a) Metal...B). Plastic?....if a replace it it was not holding system pressure anyway! then pressure test the cooling system...any radiator shop can do this...
May 7, 2007 at 8:05 PM
TRUELOVE
I replaced the broken bleeder screw and it has not overheated as of today 5/8/2007.
May 8, 2007 at 5:26 PM
