Engine Performance problem
1998 BMW 528 Two Wheel Drive Manual
This does not happen often but happens when the outside temperature is above 30 degrees celsius. The car drives fine so long as the speed is constant but when I reduce speed the car jerks for a kilometre or so and then stops, NO power! The car is still on but the revs will not go up when pressing the accellerator and then switches off. It seems as if there is no fuel going through to the engine. I will leave the car off for 15-20 minutes and restart and the car will be fine again. Once it stopped again but restarted and was fine after I had switched the car off for 1 hour.
BMW do not know what the problem is as they cannot replicate this problem and it does not show anything on the computer. "if it does not show on the computer it does not exist". Tell me that when I am stuck in traffic.
I have replaced the fuel pump twice, replaced the filters as well as the filter in the fuel tank and this has just happened again. In total, this problem has happened about 8 times but months apart.
Sep 20, 2010 at 8:42 AM
