I am getting four error codes from my scanner:
1. Catalytic Converter efficiency, Cyl 1-3
2. Oxygen Sensor Control Limit, Cyl 1-3
3. Oxygen Sensor ADaption Limit, Cyl 1-3
4. Oxygen Sensor Adaption Limit, Cyl 4-6.
I have read several forums in which I should look at my MAF sensor or vacuum leak or possibly the gas cap. Have you heard of such a problem with multiple problems showing up at one time.
I have replaced the O2 sensors, cleaned the MAF with cleaner from Autozone and still have the same 'Service Engine' problem.
Any suggestions.....
Dec 13, 2008 at 7:32 PM
