I replaced all four wheel bearings on my car and now the ABS is faulty. The ABS fault light is not on.
What happens is that when you apply the brakes, just before the car stop, the ABS comes in. It happens everytime you stop. IOW, the ABS is acting as if one of the wheels is skidding. I cleaned all the sensors, but no change.
I disconnected one wheel sensor and then the brakes works normaly, but the ABS light on the dash comes on. I also had the scanned for a fault, but the scanner does not pick any faults up.
Mar 7, 2010 at 7:14 AM
