1995 BMW 525i rear side window issue
1995 BMW 525I
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
GOPHILLS
Suddenly both electrical rear side door windows will not move up to close. So far I removed both door panels to investigate issue. When window switch is pushed to close, I hear the motor, but no movement in regulator. I can only close window by pushing up with one hand on bottom window while other hand is on the switch. Is it common for both windows to not operate? Is the issue the regulator, motor or other electrical module. If module, where can I find the module that connects with windows?
Thanks
Aug 18, 2010 at 3:26 PM
DOCHAGERTY
  • 9,603 POSTS
If the motors are operating, then the gears in the reduction box are stripped. If you get the motors out and determine that they are indeed broken/gears stripped, call Autobahn recycling @ (619)444-2290 Talk to John, tell him Dr. Hagerty sent you. They only deal with BMW and Porsche
Aug 18, 2010 at 6:38 PM
