fuel pump doesn't come on...like to know where the DME unit is on the car and also if I were bring a wire lead with switch into the cockpit...where is the best place to pick up the fuel pump hot wire?
I had the fuel pump bench checked and it works and the relay was replaced and gets voltage to the plug.
The fuel pump fuse doesn't get voltage.
I can't afford replacing the DME Module right now
Oct 21, 2010 at 3:00 PM
