Yes. The car quit, checked out fuel pump as per Bently manual, that was it. Car ran perfectly before pump died. Replaced fuel filter as well, heard it was good to do that when replacing a pump. Performed all the diognostics as per manual. Crank sensor is working, there is fuel to the rails, and spark. Fuel pump relay, fuel pressure regulator and the new pump all working. Were wondering now if we need to reset some code. After a stomp test the only code that we get is 1261, and it just keeps repeating that code, but when we check the fuel pump relay control, its fine, no short or other wiring problems.
Feb 22, 2009 at 9:51 AM
