1989 BMW 525i overheating no heat and antifreeze leak
1989 BMW 525I
14,900 MILES • 6 CYL • 2WD • AUTOMATIC
ARUFFIN2
I have a 1989 525i which recently lost heat and then begin to overheated. When I pulled over and opened the hood antifreeze looked like it was squiting out of a hole in the Idle Control Valve. Is this possible, or is there something else there that I may have missed?
Jan 7, 2010 at 3:29 PM
You might wanna start by replacing the thermostat-coolant coming out of the idle air control valve is an indication of a major trouble-could be the headgasket cracked head or block and intake manifold leak
Jan 7, 2010 at 4:15 PM
DOCHAGERTY
  • 9,603 POSTS
The M-20 motor uses a throttle body heater, cap off the hoses or replace the gasket of the heater cap at the throttle body.
Jan 8, 2010 at 8:46 AM
