1994 BMW 525i 50000 M50 tu vanos 6 cyl 2.5 car was running fine & then i read about water pumps with plastic impeller so did't know when any service to cooling system was dones so i decieded to change almost every thing so this is what i did WATER PUMP **THERMOSTAT CHECKED BEFORE PUTTING IN**HOSES - BELTS - FAN CLUTCH- EXPANSION TANK CAP & after all this seems to run hot bled system many times & still get bubbles from bleed screw. heater works fine upper radiator hose is hot but radiator does not get hot just a little warm.before i put hoses back onto radiator i ran garden hose in top radiator outlet & after about 45 seconds water comming out of lower hose was clean & no debri either any help would be nice.thank you pepperone
Nov 4, 2007 at 1:54 PM
