Cooling System Question - 1989 5254D
1989 BMW 525
ROUNDEL77
I just had a question. I was replacing my coolant and the manual said to fill until the bleeder port on the radiator starts leaking. It is taking a long time for the coolant to drop in the expansion tank and its not coming out the bleed port. When I squeeze the hoses there is still air like its not filling. Is this normal to take so long or is there a problem?
Any input would be appreciated.
Thank you.
Jul 18, 2006 at 10:31 PM
2CARPRO JACK
  • 11,533 POSTS
If the bleeder is open it will eventually bleed the air out, it may take a little time depending on if there is any build-up in the radiator to slow it down
Jul 24, 2006 at 12:49 PM
