BMW problems
BMW 525
KENWILT
My '93 525, automatic, mileage 260,000 km, leaks ATF from the connection to the transmission cooler under the rad. I've replaced the o-rings but the leak is worse.
Also, the passenger's seat adjustment control blows the fuse even when the motors are disconnected. I replaced the switch, the old one had melted, but the fuse still blows.
Thanks for any help you can give.
Ken Wilton
Aug 30, 2007 at 7:15 AM
DOCHAGERTY
  • 9,603 POSTS
It sounds like you might have pinched the o-ring at the transmission cooler or there is something wrong with the cooler itself, remove and inspect. The wiring problem sounds like a pinched or shorted wire, start with removing the seat and inspecting for damage.
Aug 30, 2007 at 12:20 PM
