1994 BMW 525 Engine Cranks, but will not turn over
1994 BMW 525
199,000 MILES • 6 CYL • 2WD • MANUAL
JHAMMER018
The car had been driving perfectly, and then today i parked it and went to work. came back out and tried to start it but it would not turn over. there were no signs of anything going wrong. the battery works fine. what could break so quickly that would stop the car from starting?
Jul 3, 2008 at 12:37 PM
DOCHAGERTY
  • 9,603 POSTS
With the information provided(Thank you for trusting us to help you) there are too many things it could be to list here in any type of order, so lets start with what has been done, and I assume you have not done anything yet other than an attempt to start the car and a visual inspection. Three things are necessary in order for internal combustion gasoline fueled engines to run, fuel, spark and compression. I will eliminate compression because we know the car did run, that leaves fuel and spark which in this case go together. So here goes with a silly question, is there fuel in the tank? Next item to consider, is the fuel pump working and is there sufficient fuel pressure? If there is spark, then a bit of aerosol parts cleaner sprayed into the intake should make the car start if only temporarily. If this proves true then fuel is the only missing component, and we are closer to getting you back on the road. If not then there will be a need to go further and I request you send me a private message to coordinate this repair as I find having to type back and forth too slow and awkward.
Jul 3, 2008 at 1:26 PM
JHAMMER018
it wont let me make a private message post until i have made 10 posts myself. but i did try the parts spray, and the car started for a few seconds. what now?
Jul 5, 2008 at 10:23 PM
DOCHAGERTY
  • 9,603 POSTS
This seems like a fuel pump issue. Check the fuses and look at the legend inside fuse box cover to get the right one and check it's integrity. Replacement of the pump and filter might be required, they are next to the fuel tank under the car, first check for power at the fuel pump. If no power then the fuel pump relay is next thing to inspect/replace, it is in the E box under the hood to the rear of the shock tower. There are four Phillips screws holding the cover on. The two square plastic relays in the center of the box, about 1" by 1" are the main and fuel pump relays, it will be either orange or green, the white one is the main relay. Remove it and tap it on something several times and try it again. Let me know how this works out, I will be standing by.
Jul 5, 2008 at 11:10 PM
