Hi, I have the work process you provided in a separate thread to replace the valve cover gaskets for the BMW N63 engine. Both of mine are leaking, and I plan to replace the gaskets. Can you please provide the work process to remove and install the fuel injectors, in particular the installation work process: remove, reinstall with pro tips, torque value to seat the injectors into the cylinder heads, etc? I will purchase new fuel injectors.
Jan 3, 2022 at 1:10 PM
