replace ball joint under 62K miles?
1962 BMW 330
DSMITH8809
I recently had the 60K mile service II inspection done on my 2001 BMW 330i (std transmision/ sport pkg)and they are recommending I replace both ball joints. This seems unusually early. I had it done on my 92 325 between 80K and 90K.
I understand that while there is no exact lifespan that can be put on a sealed ball joint, they can fail as early as 125,000 miles. Signs of a failing ball joint start with a clicking or snapping sound when the wheel is turned and eventually turns into a squeaking sound at the end of a stop, when the gas pedal is used and/or also when hitting bumps.
My car is not exhibiting any of these symptoms. Can I run with it for awhile longer, or should I spend the $ now?
Oct 26, 2007 at 2:50 PM
MERLIN2021
  • 17,250 POSTS
Best thing to do right now is to get a second opinion, if you have any doubts! Or jack it up yourself and put 1 hand at three and the other at 9 and shake, then put hands at 12 and 6 and shake, then place a bar under the tire and check for up and down play, if any movement is detected, replace them! You don't need to wait till the are unsafe to change them!
Oct 26, 2007 at 2:53 PM
