2007 BMW 330 Timing chain
2007 BMW 330
BECKYSCREECH
  • 5 POSTS
Engine Mechanical problem
2007 BMW 330 6 cyl Two Wheel Drive Automatic
I would like to know the procedures and or a walk thru for setting the timing and vanos on the engine thanks in advance.
May 30, 2009 at 1:31 PM
DOCHAGERTY
  • 9,603 POSTS
I need to get into my storage to get the procedure for you, I will repost Sunday afternoon.
May 30, 2009 at 6:19 PM
DOCHAGERTY
  • 9,603 POSTS
Is this an E-90? There isn't a timing procedure and Vanos is directly related to the cam timing and does not require a separate procedure.
May 31, 2009 at 11:44 PM
BECKYSCREECH
  • 5 POSTS
[quote:c609c1d4f6="Dr. Hagerty"]Is this an E-90? There isn't a timing procedure and Vanos is directly related to the cam timing and does not require a separate procedure.[/quote:c609c1d4f6]I dont understand you there got to be a procedure for changing timing chain on any engine you cant just place it on any way there got to be marks and so on please explain.
Jun 1, 2009 at 8:05 AM
DOCHAGERTY
  • 9,603 POSTS
Do you know the motor's designation? Is it a N-52 or M-54?
Jun 1, 2009 at 8:35 AM
BECKYSCREECH
  • 5 POSTS
the motor is a M54 double Vanos inline six cylinder
Jun 7, 2009 at 8:28 PM
DOCHAGERTY
  • 9,603 POSTS
There are several special tools required to set the vanos, the position of the cams, the intermediate chain, and the crankshaft. These tools may be cost prohibitive to buy and use but once, did you intend to follow through with this to completion?
Jun 7, 2009 at 9:24 PM
BECKYSCREECH
  • 5 POSTS
Yes I want to follow through with this procedure please let me know the tools needed and or part # I have a source on ebay that sells all specialty tools for BMW
Jun 8, 2009 at 6:01 AM
DOCHAGERTY
  • 9,603 POSTS
I saw the E-bay posting, that is the VANOS tool, there is also the cam blocks and the pin for the crankshaft that is not included in that kit (at least that I could see) I did see that Baum tool has the pin, part# 112300, and the cam blocks part# 113240. The procedure is on my computer in storage, I will go to it today and repost the procedure before the close of business today, I promise, and thank you for being patient ♥
Jun 8, 2009 at 9:53 AM
DOCHAGERTY
  • 9,603 POSTS
I am having some technical issues and will get to the posting as soon as my technical support(my youngest son) calls, tonight I am hoping.
Jun 8, 2009 at 5:40 PM
BECKYSCREECH
  • 5 POSTS
Ok bro no problem, will be waiting....
Jun 8, 2009 at 8:13 PM
DOCHAGERTY
  • 9,603 POSTS
Are you going to take on that repair still?
Aug 16, 2009 at 11:51 AM
