2001 BMW 330 trouble code p1260 P09F6 FAULT CODE.FUEL RAIL
2001 BMW 330
71,762 MILES • 6 CYL • 2WD • MANUAL
FULLYLOADEDCARS
Hello
BMW 300 turbo diseal came in this morning not running
Put the scanner onit and the codes were
P1260 + P09f6 were displaied
I looked the codes up and i'M getting loads of differebt answers...
Can anyone help???
Vin : wbael92080jz83127
Engine code : 30 6d 1
many thanks
Marco
Jul 11, 2008 at 4:53 AM
DOCHAGERTY
  • 9,603 POSTS
The P1260 code shows a possibility of theft deterrent as the source, there is also a fuel cut-off issue that is possible, what scanning device are you using to extract these codes?
Jul 11, 2008 at 5:12 AM
FULLYLOADEDCARS
thanks for your quick reply
I'm using the snap on solus
Ivgot fuel comming up and out of the filter into the inj pump but its not going from the pump to the injectors
could it be the solinoid on the pump?
Jul 11, 2008 at 6:13 AM
DOCHAGERTY
  • 9,603 POSTS
My response to your question is yes, however I am in the US market and BMW does not offer the diesel power plant here yet and I am unsure of how much assistance I can be. I would say the Snap-on scanner would be fine for most applications, but it will only tell you what is being generated from a generic standpoint. If you can get access to the proprietary BMW software (it's called a GT-1) and access the codes, I could be of better aid to your issue.
Jul 11, 2008 at 7:02 AM
FULLYLOADEDCARS
hello
sorry its taken me so long to reply
the fault on that bmw for a interminten fault on the lift pump chandged it and the car is running fine..
thanks for your help
marco
fully loaded cars
Jul 22, 2008 at 11:08 AM
DOCHAGERTY
  • 9,603 POSTS
Thanks for the feedback.
Jul 22, 2008 at 10:26 PM
