2001 BMW 330 Error P0335 Crank position sensor ckt a malfun
2001 BMW 330
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
LADU
Error P0335 Crank position sensor ckt A malfunction
I have replaced the sensor but still the same problem,
where will i find the ckt A and what will it take to fix it.
thanks allot.
Mar 7, 2009 at 6:06 PM
DOCHAGERTY
  • 9,603 POSTS
So lets recap, You had a crankshaft position sensor fault, you replaced the faulty sensor with a new sensor from a known good source, and you then cleared the fault, reset adaptations and the fault came back, is this correct?
Mar 7, 2009 at 9:23 PM
LADU
yes u are right no improvements code somes back.
Mar 10, 2009 at 3:57 PM
DOCHAGERTY
  • 9,603 POSTS
What method are you using to extract this code?
Mar 10, 2009 at 8:31 PM
