1999 BMW 328 cooling system
1999 BMW 328
ANGEL AMRTINEZ
  • 5 POSTS
1999 BMW 328 6 cyl Two Wheel Drive
my car is getting hot,coolent is not leaking
Apr 4, 2008 at 5:59 PM
MASTERTECHTIM
  • 4,750 POSTS
how hot? is the cooling fan coming on? is it boiling over?
Apr 4, 2008 at 6:07 PM
ANGEL AMRTINEZ
  • 5 POSTS
i had replace the extended tank and i steel have the signal ,check cooling system,do this model has a termostate and where is located.?
Apr 4, 2008 at 6:30 PM
MASTERTECHTIM
  • 4,750 POSTS
the thermostat is in the middle front of engine. follow the upper rad hose to the housing. it all comes as one piece.
Apr 4, 2008 at 6:38 PM
DOCHAGERTY
  • 9,603 POSTS
There is a coolant level sensor in the expansion tank. Did you reconnect it? Is the coolant level too low? If not, then you might need to replace it, they do fail. Repost if more help is needed.
Apr 4, 2008 at 7:56 PM
ANGEL AMRTINEZ
  • 5 POSTS
i did reconected the sensor on the bottom of the tank ,do i need to replaced it ,the cooling level was fine
Apr 5, 2008 at 7:25 PM
MASTERTECHTIM
  • 4,750 POSTS
yes replace it
Apr 5, 2008 at 7:33 PM
