Hi, how do i add transmission fluid on my 1999 E46 328i . is that resavor That says ATF on the cap where i add it, or is it somewhere else?
May 30, 2008 at 11:48 PM
DOCHAGERTY
CERTIFIED EXPERT
There is a filler plug on the transmission, right side, above the oil pan, towards the rear, use an 8mm Allen to remove the plug and fill with the engine running.
