1998 BMW 328 Sway Bar Links
1998 BMW 328
223,000 MILES • 6 CYL • FWD • MANUAL
ALEXS-MOMMA
I took my 98 328i to have the front end checked out because of some noise it was making over bumps. My mechanic told me that my front end needed sway bar links as well as front to end bushings. Is the problem as simple as that? No struts needed?
Mar 30, 2008 at 8:42 PM
DOCHAGERTY
  • 9,603 POSTS
At 223k I would think the suspension would be worn to the point of replacement, however the fact is that I am not there and if the tech that is helping you decides the work should be performed, then you have a decision to make.
Mar 30, 2008 at 10:54 PM
