1998 BMW 328 how much
1998 BMW 328
180,245 MILES • 6 CYL • 2WD • AUTOMATIC
UBE
how much does it cause to fix the computer on my car?
May 5, 2010 at 1:48 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
When you say fix the computer on your car has a fault been isolated in the ECU? do you have a fault code showing up? what exactly is the problem you are having, i ask this as direct ECU faults are not often seen and are normally only diagnosed with the ECU out of the car and tested by a specialist in a test rig.
Mark (mhpautos)
May 5, 2010 at 1:52 AM
UBE
it has been showing the check engine and evry other day it say check controll
May 5, 2010 at 2:33 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Start with the diagnostic scan and check for any unresolved fault codes, start here.
mark (mhpautos)
May 5, 2010 at 2:52 AM
