1998 BMW 328 Blower/Heating problems
1998 BMW 328
RYAN82586
  • 11 POSTS
Heater problem
1998 BMW 328 6 cyl Two Wheel Drive Manual 160k miles
6 out of 7 days my cars heat will work; its like it has a mind of its own. The day it chooses to not work there is very little residual heat coming out of the vents, but its like the blower isnt working. What could be causing this? Blower motor malfunction? Secondary Air Pump malfunction? Blower Motor Resistor malfunction?
Let me know what you think....thanks!
Mar 11, 2008 at 11:11 PM
DOCHAGERTY
  • 9,603 POSTS
BMW uses a solid state device referred to as a final stage that actually controls the fan. They can and do fail and with the symptoms you describe. 64-11-8-380-580 should be the correct part number. It is located on the drivers side and the under dash will need to be removed to access it.
Mar 12, 2008 at 12:44 AM
