1996 BMW 328 Transmission slipping
1996 BMW 328
151,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRAVLINMAN314
Background: At about 145,000 milles, lost traction control, warning lights came on along with Check Engine light.
Shortly after, transmission started eratic shifting, but worked OK in manual mode. Took car to mechanic. Changed out a module, shifting in Drive mode now better.
149000 miles, transmission started acting up, slipping a little and tranmission light came on, while going into only 3rd and 4th gears as manual said it would. Some days were better than others as far as acting up.
151,000 miles, loosing 2nd and 3rd gears, slipping while starting forward motion, then catching on.
4th gear and Overdrive work fine as long as Trans> warning light stay off, and that can be reset by shutting down and restarting.
My question more or less concerns replacing transmission, should I throw good money after bad for a "used" transmission? I have chanhed clutches and transmissions in domestic vehicles, (Fords and Chevys).
Would like this vehicle to make it 50K more miles before replacing.
Should I shy away from used? Is rebuilt the way to go?
Does the traction control problem stem from the transmission? Will changing the trans out solve both problems?
I can handle an honest answer, even if it consists of me pushing the car over a cliff.
Thanks!
Feb 26, 2008 at 7:55 PM
DOCHAGERTY
  • 9,603 POSTS
The transmission and traction control warning are most likely not related. The transmission is rebuild able or can be replaced with a remanufactured unit at moderate expense, you have to decide if it is worth it to spend $ on a car. It is difficult for me in cyberspace to give an opinion about the car without having seen it, if it's really clean, and I just loved the car, then yeah I would fix it, it all depends on how much value you place on it.
Mar 11, 2008 at 9:25 PM
