RE: 1985 bmw 325e
1985 BMW 325
HAWKSRNO1
how do you replace the odometer gear?
How do you access the odometer?
mileage 202419
engine size 2.7 liters
Jun 25, 2007 at 9:16 PM
DOCHAGERTY
  • 9,603 POSTS
removal of the instrument cluster requires dropping the under dash in the drivers footwell to access two thumb screws that hold on the plastic panel just below the cluster, then remove the phillips screws that retain the plastic surround and then two screws holding the cluster in. A speedo repair shop can help you with this repair.repost if you need more help
Jul 24, 2007 at 5:56 AM
