frozen door locks
BMW 325
RON LUTSOCK
1995 BMW 325 i with 200,000 miles - recently relocated from LA to Nebraska - having problems with the door locks freezing when experiencing icey snowstorms. What can be done to prevent this short of moving back to California?
Jan 1, 2007 at 2:01 PM
PRIMERGRAY
  • 13 POSTS
I Maybe Wrong But Your Car Should Have Door Lock Heaters, When You Pull Up The Door Handle It Is Supposed To Activate The Door Lock Warmer
Jan 23, 2007 at 6:56 PM
SERVICE WRITER
  • 9,123 POSTS
In the event of no heaters, you can try to spray some wd-40 into the locks as it displaces water. OR carry a lighter and heat the key before sticking it in. One last strategy is to use an empty toilet paper roll, place one end on the lock and blow into the other to heat it with your breath. Short of that, replace the lock.
Jan 23, 2007 at 7:54 PM
MCS
wd40 has an automobile lock lubricant that will prevent freezing, just make sure to use it after every car wash.
Feb 13, 2007 at 9:41 PM
