2004 BMW 325 Oil in the radiator
2004 BMW 325
33,000 MILES • 6 CYL • 2WD • AUTOMATIC
RFB
My mechanic found oil in the radiator. He said it was caused by a cracked head gasket. Is this possible?
Oct 25, 2010 at 6:31 AM
KHLOW2008
  • 41,814 POSTS
Hi rfb,
Thank you for the donation.
Yes, oil in radiator could be due to a cracked head or bad head gasket. This should be coupled with coolant losses and overheating issues.
The engine oil would most likely be contaminated with water as well.
Oct 25, 2010 at 8:08 AM
DOCHAGERTY
  • 9,603 POSTS
Oil in the radiator could also be the heat exchanger for the automatic transmission is allowing oil into the cooling system.
Oct 25, 2010 at 9:39 AM
