Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
BMW
325
Engine Cooling
Radiator
2004 BMW 325 Oil in the radiator
2004 BMW 325
33,000 MILES • 6 CYL • 2WD • AUTOMATIC
RFB
MEMBER
1 POST
FOLLOW
My mechanic found oil in the radiator. He said it was caused by a cracked head gasket. Is this possible?
Oct 25, 2010 at 6:31 AM
KHLOW2008
CERTIFIED EXPERT
Hi rfb,
Thank you for the donation.
Yes, oil in radiator could be due to a cracked head or bad head gasket. This should be coupled with coolant losses and overheating issues.
The engine oil would most likely be contaminated with water as well.
Oct 25, 2010 at 8:08 AM
DOCHAGERTY
CERTIFIED EXPERT
Oil in the radiator could also be the heat exchanger for the automatic transmission is allowing oil into the cooling system.
Oct 25, 2010 at 9:39 AM
