2003 BMW 325 Pass Window Mirror
2003 BMW 325
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
JWCZERWINSKI
The passanger mirror does not move, took the motor out and tested it is OK, Took the drivers door window mirror switch out and it tested fine, also checked fuse #25 5 amp fuse it is also fine,, where could the problem be?
Jan 15, 2010 at 2:47 PM
DOCHAGERTY
  • 9,603 POSTS
The general module is in control of the mirrors through a LIN bus. http://en.wikipedia.org/wiki/Local_Interconnect_Network
The bus might be down, try disconnecting the battery for several minutes, reconnect it and see if the problem goes away, this is a reset, like control/alt/delete on a computer.
Jan 16, 2010 at 9:32 AM
