I have removed the tire, brakes, roter and my instruction manual says to remove the driveaxle first so I removed the driveshaft nut and next it says to remove the bolts securing the driveaxle constant velocity joint to the differential unit however, I can't find any bolts to remove.
After removing the driveshaft nut should the driveshaft come off? If so, how does it come off?
Where do I find the bults securing the driveaxle cv joint?
At the moment I fell as thou I am in a little over my head but I'm hoping you can help me out!!
Dec 27, 2007 at 5:53 PM
