2003 BMW 325 bmw 325 xi
2003 BMW 325
116,035 MILES • 6 CYL • 4WD • AUTOMATIC
NSLOAN
I have a BMWxi All wheel drive and I am looking for a part on line and can not find it, It is betwqeen the Front drive shaft Assembly and the Rear Drive shaft Assembly, It is a gear box of some sort. I have some play in the front Drive Assembly and Just trying to get a quote on how much one would cost before it totally breaks. or How much willl it cost to fix it.
[img:4664b76ad1]http://www.2carpros.com/forum/automotive_pictures/416005_1912_1.jpg[/img:4664b76ad1]
Sep 30, 2009 at 8:38 PM
DOCHAGERTY
  • 9,603 POSTS
Do you mean the transfer case? What is it that has you think it is broken? Have you searched the salvage yards? How about Realoem.com
Sep 30, 2009 at 9:36 PM
NSLOAN
Well I was hit from rear,from someone who was not insured and my insurance will not cover it because they stated it is normal wear and tear, I have some play on that axle that you can turn about a 1/4 turn which it should not have no play init. when I drive and put the gas to it I feel a vibration that feels like mmy tires need balancing or a knot in my tire.
Sep 30, 2009 at 10:05 PM
DOCHAGERTY
  • 9,603 POSTS
You might want to rule out the tires/suspension as contributing to the issue before spending money on a transfer case. I have personally been stuck with the tab once or twice when I was wrong with the diagnostic, dont let it happen to you. How can being hit from the rear be normal wear and tear?
Sep 30, 2009 at 10:09 PM
NSLOAN
That is what I said, and they will not fix it because they stated after 100k miles it needs to be replaced, that is what I need to find out, will getting hit from behind cause that much sliipage on that drive axle.
Sep 30, 2009 at 10:25 PM
DOCHAGERTY
  • 9,603 POSTS
I think it might be time to speak with an attorney about this issue.
Sep 30, 2009 at 10:43 PM
