2002 BMW 325 Transmission vs gear assembly
2002 BMW 325
SAILINIT
Transmission problem
2002 BMW 325 6 cyl All Wheel Drive Manual 90k miles
I have a 2002 bmw 325xi. For more than a year I have had trouble shifting gears when it is cold outside (<50'f). The gear shifter, while in neutral will pull hard to the right and sit over by 5th gear. Then to shift gears I have to pull it back to center to find third. It is also getting increasingly rough to shift - catching on something left sided when going into 1st. Once in gear the acceleration is phenomenal. I've been told that it is the transmission, but I think it may be the gear shift assembly. Hmmm?
Nov 25, 2008 at 7:54 AM
DOCHAGERTY
  • 9,603 POSTS
This sounds like a bent shift fork or something internal to the transmission and less like a shift linkage or platform issue. Have you tried changing the gear box oil to synthetic or tried Redline oil? Try that first and let us know.
Nov 25, 2008 at 11:17 AM
